waqasmalik
Hi all, i have a question regarding specific heat capacity of aluminium. Thermal conductivity of copper is highest among steel,aluminium and copper. If we compare copper and steel then we see that to raise the temperature of one kg of copper to one degree centigrade we need less heat as compared to steel because steel has 1/6 of thermal conductivity as compared to copper, heat will move slowly . Now , if we talk about aluminium then it has its thermal conductivity more than that of steel but less than copper.As a result it must have high specific heat capacity as compared to copper but less than that of steel.If we have a look at technical literature then we see that the specific heat capacity of aluminium is twice of steel. What could be the reason behinde this?
THANX ALL IN ADVANCE
