wroggent
- Aug 20, 2012
- 288
We recently had a surge in a plant 'due to one the utility's fuses blowing.' The surge destroyed 3 contactors in one of our MCCs. We don't currently use any SPDs in the plant with a possible exception to small point of use units, e.g., integrated in a power strip. I've done a bit of reading on SPDs and I understand that there can be a great variability in there effectiveness, depending greatly on where or how they're installed. For example, wall units that potentially make use of long leads are less effective than (panel) integrated units because of the inductive reactance introduced by the leads. So far I've only looked at GE and Eaton's offerings for SPDs. Eaton offers a unit that supposedly is designed for installation within an MCC. Do any of you have experience with these units? The intention of installing an SPD in the MCC would be to avoid damage to the MCC components (and also connected apparatus) due to a surge from occurring again. Would the SPD function effectively in this capacity? Would the placement of the SPD in the MCC be a significant consideration, i.e., are the buses in an MCC of sufficiently low impedance to allow free placement of the SPD? What approach would you suggest for avoiding damages due to surges (internally or externally created) in a plant? MCCs are 1600A 480Y/277V from various manufacturers.
