Some wires coming off the structure (Shell element) after loading.
Mohamed Zied
43
I build a 6 girders bridge using shell elements and I used wire for bracings. I ran my model successfully without errors, but I got some of the bracings (wires) coming off the structure as you can see in the pictures. the load is just a self-weight and deck load.
Does anyone know the reason? and how to fix it?
Thank you in advance.
 https://files.engineering.com/getfile.aspx?folder=34ad8be9-fa61-424e-9115-d03678a89975&file=9-28.pdf
It seems that they are disconnected initially. Which method did you use to attach wires to shells ? Were these parts merged ?
I merged the shell parts as you recommended, so now all shell elements are merged in one part in which, I added wires to model bracing and truss members.
Should I merge again, shell members, and wires??
Maybe some of the wires were separated from the shell before merging. Make sure that there’s no gap between these parts.
