Some questions in relation to Femap 8.2
StructuralGenius
NL
I started a couple of days ago working with Femap. But while solving a wiremodel. There will always be the following error:
0 warning(s) and 1 error(s) occured during analysis. Review results carefully.
Another questions is: how can I obtain the reaction forces and displacements printed in a list?
Are you using FEMAP Structural Solver, or are you using another program to solve the system after preprocessing with FEMAP?
Can't really help you with the error message, since I'm using ABAQUS as solver. But there may be a problem with boundary conditions that do not sufficiently constrain your model.
To write results into a file you can use the command List/Output/Unformatted (or Formatted, what ever you prefer). Previously you have to chosse the destination with List/Destination
Rudolf
Thanks Rudolf for your help with my second problem, that is solved now, but the first one is still a problem.
Is there a possibility to make an attachment, so that I can add my FEMAP-file?
Hi StructuralGenius
I don't know how to attach a file in this forum. But you can send a NEUTRAL-file to femap@bluemail.ch. I'll have a quick look.
Rudolf
