gunnykiln
- May 14, 2004
- 78
I have one assembly sketch that about 15 parts are derived from. The assembly master sketch contains several different blocks for the different parts. I created the parts in assembly, created part sketch, then highlighted the appropriate assembly master sketch block, and convert entities. Now when the design assembly is almost complete I need to make some changes I am having some problems:
1. When I edit a sketch block and mirror some lines the derived part does not update and I get the part error: "This sketch contains dimensions or relations to model geometry which no longer exists..."
2. When I move a sketch block in the assembly master sketch the derived parts come up with the above error.
Are sketch blocks bugged or am I doing something wrong?
