7 Pages pretty short for Vs. Rants Glad I didn't look at the 33page one yet. maybe it just has a lot of sneaker adds.
Most of what Pro/E has put into WF5 is to make it more like SolidWorks in terms of Sketcher. Ellipses have been possible in Pro/E for a long time but before they came out with the ability to place them at an angle other than H/V axes Rotate one and you were limited to 90 degrees at a time which has been that way since before Intent Manager. The only workaround to this was to create the Ellipse using a conic with elliptical rho value and a series of angle tangents and symmetry constraints. Another thing that annoyed me about Pro/E was having to select the constraint you want and then pick the entities. SolidWorks has had the ability to CTRL select entities and give you choices based on selection. They even have a context toolbar that pops up to show you the constraint. Pick 2 lines and you can make them Equal and Perpendicular with two clicks. Now Pro/E can do this but notice he severe lack of icons. I remember making my own icons for sweep by copying the picture in the Model Tree.
For the SolidWorks fans out there. SolidWorks stole the Feature Manager from Pro/E's Model Tree and even had the idea to patent it. Major Failure for Pro/E. SolidWorks Feature Manager cannot be detached like Pro/E and can only show a few data columns. Pro/E's capability of filtering items in the tree is great however don't try to make the Column Width 2 characters the min is 3 and if you try to go lower you get a 300 width column. (Pic 1)
SolidWorks has a View Shortcut icon for dimensions however it only controls dimensions in 3d Sketches. Many SolidWorks users don't like fully dimensioned sketches so this might not be bothersome. SolidWorks shortcut keys can be customized but you'll soon wear out your CTRL SHIFT ALT TAB keys cause there is no way to have a multi key shortcut like Pro/E and even Inventor can do.
L for lines means no way to have LCSO = Layer Create SOlid mapkey. SolidWorks does have a neat new UI including Mouse Gestures and their Customize tool allows you to find any icons or print out the key shortcuts into a printable document.
Pic1
What Pro/E needs1. Ability to use 31+ char filenames including symbol chars besides #$%^@ you've probably typed worse language without needing "_" for spaces. Sometimes naming files requires a Masters in TXT Messaging.
2. Allow planes to be resized without Edit Definition-Display. (Possible in SolidWorks)
3. Be able to use a portion of sketch curves for a feature without internal sketch copy. (SolidWorks destroys proe in that respect especially with Derived Sketches)
4. Ability to control Spline combs per curve without using Saved Analysis.
5. Datum Graphs that have readable dims and can be edited without Redefine.
6. Inclusion of If Then statements in Equation Curves.
7. 3D Sketches without using ISDX.
8. Multiple Perimeter dimensions per sketch. (Try to dimension more than one arc length)
9. Ability to highlight a Layer with >500 items.
"Items in this layer exceed 500 items, and cannot be highlighted."
10. Ability to import Tables with more than 250 rows into drawing privilege.
11. CTRL+Drag copies entities in sketch.
12. Ability to have Sheetmetal Feature in Tree instead of separate Part type. (Pic2)
13. Possibility of simultaneously solving assembly constraints.
14. Ways of selecting items 1 by 1 or with selection boxes like SolidWorks has. Edit Selection style options that can be used.
Pic2
What SolidWorks needs
1. Copy Paste features that work for sweeps Lofts etc. without Library Feature.
2. Global Reference Viewer Parent Child UI (in development)
3. Sketches that can be imported saved and don't require a Part file to exist.
4. Smarter Sketch Expert that prompts for action to solve overconstraint.
5. Ability to resize dialogs in Property Manager (what good is a list of 20 selections if only 4 can be seen.)
6. Ability to select Datum points as references.
7. Reference Patterns, Multi dimension patterns patern linear and increase depth of feature.
8. Axis features that don't flip direction or order of references after creation.
9. Create points at intersection of circle/axis and plane. (Give me a side 1 side 2 option if multiple intersections)
10. Ability to use planar 3D sketch curves for revolve feature.
11. Conics with Rho value. (These can be driven by equation in 2d sketch but UI is terrible)
12. Larger Model Space 500m Diameter is the Max. you can sketch a point or line outside of this but the sketch will disappear and be unusable.
13. Ability to switch units and keep same size not same dimensions. (v18 of Pro/E could do this) NASA couldn't.
14. Allow import of System Customization while SolidWorks is open. Pick up a version of Pro/E and look at Tools Customize File Import Settings. (Pic3)
Of course you'll have to reread the registry settings but who decided to place the system settings there in the first place??? Allow a text file like Customize.sldset to be used
Pic3
I loved the this is how I feel about proe emoticon posts and have laughed my a$$ off more than I have in a while. It's good to let frustrations out but the key is to force the Software Companies to listen to their users. Kudos to PTC for removing the Resolve Mode. My zr zs zc ze zm zi mapkeys aren't needed so much anymore.
Do you want to exit Resolve Mode Y/N?
Are you serious Pro/E?
zr Resolve > Redefine
zs Resolve > Supress
zc Resolve > Clip Suppress
ze Resolve > Edit Refs (Reroute)
zm Resolve > Fix Model
zi Resolve > Investigate
Michael
Edited by: mjcole_ptc
