Solidworks-UG conflict? 1
AllenR
12
Is there a problem with running UG and Solidworks on the same machine simutaneously. My workstation is the server for UG Licenses and the floating license on SW also. If I reboot and run either program there is not a problem, if I run one program, close it, and then run the other, my machine will bog down real slow. Is this a known problem?
Thanks for any help
Allen
Perhaps you should have a machine that is not a dedicated server as a workstation?
AllenR,
Just to let you know, I can run Pro/E, SWx, and MasterCAM without any resource conflicts or system failures. I don't think being the license server would cause problems at least it doesn't with flexlm which is Pro/E's license server software. This might be a system configuration issue.
Best Regards,
Heckler
"Never underestimate the power of very stupid people in large groups" John Kenneth Galbraith
Perhaps the two programs are fighting over mutual parasolid kernel elements.
I have SW and three versions of UG running on my machine. It is not used as the license server, and I have had no problems (as of yet).
ewh, how does UG compare to Solidworks in your opinion? Which did you start out on?
Jason Capriotti
Smith & Nephew, Inc.
Jason,
I started out on UG about 15 years ago. The company I work for designs and manufactures composite parts for aerospace, and we have 10 seats of SW vs 2 of UG. UG was brought in to handle some of the complex surfacing and because some of our largest customers use it exclusively. I must admit that I don't use SW very extensively, since it is much quicker for me to use UG. Having said that, I do think that SW is a very good and powerful program for the money. Except for some of the advanced surfacing, associativity and manufacturing capabilities of UG, I think that SW comes out ahead.
