davidneedshelp
Automotive
I am trying to trim a surface using a sketch. It works, but the trim projects through all surfaces, not just the one I wish to modify - there is no option to set a direction/depth as in 'cut' with solids.
Is there another way? I have tried creating an extruded surface from the sketch, then a combination of trim and delete surface, but it will not let me delete all parts of the trim surface and looks an untidy solution.
Thank you for your help.
