Lets face it; most folks never use the majority of "new capabilities" that they keep coming up with. It seems that the basic modality (sketches, extrusions, cuts, revolves) never changes.
That's not true.
A lot of people use the new features. (Where do you most of these new features come from?....Users) I use the Multi-body a lot more now that it's available. You can't use that in SW01+ and if we are able to save back to an older version. How do you think SW01+ would accept that... with and error, that's how it would see a Multi-body.
In some instances the way a sketch is created is different from version to version. The way the extrusion or cut was made is different from version to version. (EX: in SW03 there is an option "Up to Body" that option is not in SW01+. How would SW01+ respond...Error.
If the multi-body was the first (Or base extrusion) there wouldn't be model left because after it couldn't figure out how to build the multi-body then the rest of the tree would collapse in on itself and the model would be trash.
You would be better off sending it out as a Parasolid, IGES, or step than you would be at saving back a version...Which this is what your doing now to get your models transferred.
I hope you understand my logic of why I think transferring back a version would really not be a benefit vs. how we transfer back now. Although I understand the need to transfer back a version.
Regards, Scott Baugh, CSWP
![[americanflag] [americanflag] [americanflag]](/data/assets/smilies/americanflag.gif)
3DVision Technologies
faq731-376
When in doubt, always check the help
