SolidWorks 2010 Service Pack 1.0 EV (Early Visibility) is now availabl
Heckler
1,932
The EV release is available for download at
Notes:
Performance reporting is turned on for EV releases.
Report critical problems to SolidWorks Technical Support at evis@solidworks.com.
The full version is scheduled 2 weeks after the EV version and is subject to change without notice.
Heckler [americanflag]
Sr. Mechanical Engineer
o
_`\(,_
(_)/ (_)
This post contains no political overtones or undertones for that matter and in no way represents the poster's political agenda.
Don't you also have to uninstall the EV patch before applying the actual next service pack (SP1) if additional problems were fixed since EV?
Michael
It depends on the SP. I can only remember one EV SP that had to be uninstalled before installing the official released SP since I have been using SW (2003).
Cheers,
Anna Wood
Anna Built Workstation, Core i7 EE965, FirePro V8700, 12 gigs of RAM, OCZ Vertex 120 Gig SSD
SW2010 SP0, Windows 7
As far as I know you do not need to remove the EV patch. You should be able to install over top of it. However do not upgrade from one major version to another.
Plus turn off your Anti-virus... its a safe bet.
Scott Baugh, CSWP [pc2]
"If it's not broke, Don't fix it!"
faq731-376
