rupika
- Apr 3, 2010
- 41
Hi all,
I use SOLID65 element to model reinforced concrete structure. I have a problem to select material number in element attributes window. I entered two materials MAT 1 for concrete and MAT 2 for rebar 1. Then what should I select for this case. If I select MAT 1 will it ignore rebar 1 for that element? I have confused. I have attached the document. Can anyone help me? Thank you.
