SOLID65
rupika
41
Hi all,
I use SOLID65 element to model reinforced concrete structure. I have a problem to select material number in element attributes window. I entered two materials MAT 1 for concrete and MAT 2 for rebar 1. Then what should I select for this case. If I select MAT 1 will it ignore rebar 1 for that element? I have confused. I have attached the document. Can anyone help me? Thank you.
you have to assign Mat 1 to your concrete model using element attributes and assign Mat 2 for rebar in real constants of solid65.rebars are not shown in the concrete model and are smeared in it.
Engineering Softwares Company
