laxhuskie9
- Mar 4, 2009
- 5
I have two solid rings of the SAME MATERIAL, the lengths of which, are not important. The inner ring has a "bump" on the OD, and the outer ring has a "bump" on its ID, thus creating a slight interference (0.016 difference in Diameter). I need to calculate both the force required to push the outer ring past the inner ring, and the pressure/stress that the inner ring induces on the outer ring. Here are my dims:
Outer Ring OD: ODo=18.59in
Outer Ring ID: IDo=17.91in (this includes the bump)
Inner Ring OD: ODi=17.926in (this includes the bump)
Inner Ring ID: IDi=16.72in
Width of each bump = 0.18in
Each side of bump has 30deg chamfer leading to dia.
Yield Strengths = 75000psi
Modulus of Elasticity = 30x10^6psi
Poisson's Ratio = 0.295
I am treating the inner ring as a solid ring, therefore requiring the outer ring's bump to deflect outward to the inner ring's "bump" OD, allowing the outer ring to slip past the inner ring bump. Temperature is not an object here so do not take into consideration thermal expansion.
I've found information regarding interference fits on this forum, but it doesn't seem to apply to my problem (to my knowledge).
Sorry this is so long, but I really need to figure this out. Let me know if I have left any information out.
Thanks!
Thanks!
