Guest102023
Materials
I am looking at replacement of about 100 feet of 16~24"Ø pipe that requires Hastelloy on the process fluid side. Current material is steel, thickness 3/8". We are still in the early design stage. I believe the thickness will be driven by the structural requirements (process pressure and temperature are fairly low). However I don't yet have information about the minimum thickness requirement. I have an aversion to fabricating from clad materials, because I have seen so many done so wrong. However I realize the choice will always be driven by cost, and that for every equipment there is a break-even point in terms of thickness.
So I have some questions:
(1) Is roll cladding still the dominant technology? What other methods are used?
(2) What is the lower practical limit for making clad steel? (Assuming 3mm (1/8") clad thickness)
(3) Are there any material integrity concerns when rolling clad plate (say, 1/2" total thickness) down to 16"Ø?
Any other advice or comments are welcomed.
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
