SOL 600 - Output requests
rskumar88
Aerospace
DE
Hello all,
I am trying to simulate progressive failure analysis of composites using SOL 600. I am post processing the Marc T16 file in patran for the results. I am using displacement controlled load. So I need to have the "costraint forces" data to plot my results. But, in SOL 600 I am not able to see the "Constraint Forces, Translational" in the results. How can I get it ? Thanks.
Kumar
Hi rskumar88,
In your input file (.bdf, .dat...) check if:
-SPCFORCES(PLOT,SORT1,REAL)=ALL is present
-PARAM,NOCOMP,YES is not defined, if this is the case remove it.
SN
Seif Eddine Naffoussi, Stress Engineer
33650 Martillac – France
Hello SN,
Thanks for your reply. But I cannot understand your answer. i am attaching my bdf file and the dat file. Can you please help me figuring out where should I include these commands. Thanks.
Kumar
 http://files.engineering.com/getfile.aspx?folder=949ce41a-e60d-4e2e-bdf9-2db14a1d938c&file=failure_openhole.marc.dat
