SOG concrete work failing! 6
s0hanc01
Geotechnical
Background: The site is an industrial site in Houston, TX used to store containers, large compressors, i.e. heavy items for offshore piping services. Semi's & a huge RT fork lift are the main loads in concerned. There is a main drain for water.
Problem: I did not see the previous installment nor do I have access to drawings. All I can tell is that the concrete is in about 20'x20' sections (between expansion joints). Where four sections meet (in several locations about 1300 sq ft) the concrete has cracked and settled in some cases close to 4 inches. Not all the concrete was poured together..this is why only some concrete has failed.
I think this is do to ponding water seeping into the backfill through expansion joints, then the truck drives over and causes a build up of pore pressures, which in turn cracks the concrete.
To prevent this I have a couple ideas:
Repour concrete so that no ponding water occurs.
Backfill possibly was done wrong? 2' DGA compacted and compaction test to confirm.
Slab Design - not enough rebar, strength, dowels
Put in more drains
Finally what about caulking joints with a waterproof caulk so that water can't get below concrete. Or am I missing the point, Does the water come from below. Hard to say without knowing depth to water table.
I think the soil i s Beaumont clay: I obtained this from websoilsurvey.
hokie66-
I agree. I just want to highlight that stresses (although not much) do exist within a freshly poured slab/structure. :)
DiggDug
"Things change but nothing changes"
"Beaumont Clay", known locally as slick grey dog-s*** taffy.
Most likely comes with a high water table. Its impossible stuff to work with. Hardly ever dries out, but if it does it cracks into coffee saucer size plates and sometimes curls up almost into a coffee cup. If 4 wheels hit it at once, you'll all of them spin forever.
Good luck.
"Being GREEN isn't easy" ..Kermit
