thekman
- Sep 3, 2009
- 90
208 3phase w/ neutral service. 3hp 3ph 208-230v motor rarely if ever used to charge hydraulic cylinder. Smart relay control, typical setup used in 100's of locations with similar or identical scenario.
2 outputs (dry contact relay) wired to run traffic lights (120v 60W bulbs) from of 1 leg (through smart relay output) and return to source neutral. Technician verfied .5a on both hot and neutral to light that's on.
4 identical systems, 2 sets of 2 within a few hundred yards of each other, all burning up the plc outputs' contacts.. ..JUST the 120vac (voltage in = L3-N) output that is on is burning up. These (nor any of the others) are being turned on or off, it's pretty much just sitting there on all the time.
The location is within a mile of the ocean, so I'm thinking the air has something to do with it, and maybe a combination of the salty humidity mixed with some harmonics on the neutral, although not sure what might generate harmonics if nothign is sharing source.....?
To my knowledge, there's nothing else on the source, and the only other things on the 120vac circuit are some solenoid valves and a contactor, yet none of which are used.
It's as if the made contacts are just somehow building up contaminant, pushing the contacts apart just enough to arc the 120.
Any thoughts?
Any thoughts?
