drag can be a very fnickety thing ... we had a mod (on a plane) where we were deflecting the airflow around an open door; in development it worked well, then they "productionised" the deflectors, changed some edge radius a little ... damned things didn't work, had to redo the development work with the productionised pieces.
if you can't access the tape (and "copy" it), can you do CFD ? i wouldn't trust the results without a test but they should get you some way along the path. if you can't do CFD then you're stuck with testing things. if you don't want to do this, see the previous post about using a bigger tube. i doubt that there is a canned solution for your problem.
again, how much are you trying to gain ? is the power required 2* what you want ? 1.1* ??
Quando Omni Flunkus Moritati
