YateHaugan1
Aerospace
Hi everyone,
I'm trying to find a suitable solution for the actuation of an airline seat prototype.
The seat will be moved by a rack and pinion set up and a single stage of gearing.
I need between 60 and 80 rpm at the motor/drive output and at least 70 Nm of torque.
The motor/drive needs to fit into the smallest volume possible, with the lowest weight. Cost is less of a problem.
So far the only motors I've discovered that come close to doing the job are Maxon's 4-pole items, but they would all require additional gearing stages (even with the planetary gearboxes they offer) to get the rpm down suitably and provide suitable torque.
If anyone knows of a suitable product or manufacturer it would be great to know. It's just a prototype at present, so I won't be able to buy in bulk.
thanks
TJ
thanks
TJ
