Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Okay. That makes sense. Different regions, different approaches. Also makes sense that the connection at least seems to have some thought put into it.retired13 said:As I am aware off, the detailer's office usually have structural engineers (licensed, or by trade) to perform one job only - design the connections.
Why would it be? You are adding more steel.Veer007 said:Guys, slotting HSS column at base would not be an issue?
retired13 said:The only thing bothers me is I don't know how to analyze the gusset as shown now.
JAE said:Essentially they are demanding that you weld on the inside of the tube column to the gusset plate.
KootK said:For the sake of argument, imagine that our column here was really a double channel. Would OP's weld symbol be appropriate then?
retired13 said:Guessing from the geometry, the 1/2" connecting plate may suffer approximately 15 kai compressive stress. It's ok, or not?
retired13 said:Quite impressive.
