Longspan roof deck on longspan roof joists. The profile of the roof required the deck to slope perpindicular to the joist.
Is the deck required to sit flat on the joist? All i see is a 1 1/2" bearing length requirement just to prevent slip off.
Should the joist be rotated about it's long axis or instead some sort of shim welded to the top chord to provide a sloped bearing surface?
