Hi Lutfi,
Not having my green book, err should I say my dark blue book now I guess, with me right now, I can't remember exactly, but there is a table in the RCSC spec at the back which lists the finishes acceptable for slip critical surfaces. I can't remember if it says galvanized is OK, but definitely inorganic zinc will work. In fact, with IO zinc you can get Class II (?) surface which will give you higher allowable loads than in the slip critical tables, which are based on Class I (?) surface. I think it also covers any further surface prep after coating to achieve desired results, like a light wire brushing, or something like that. With the IO zinc higher load capacity, and no taping of joint areas like regular primer, you get a double benefit, if corrosion is a major concern. Plus the IO zinc makes any finish painting much easier than hot dip.
