TC bolts are the way to go. I haven't seen a DTI in about 7-8 years. They are clumsy to use.......You need the gage.
Most if not all the erectors in my area (NE-CT) use TC bolts. Even if the SER does not specify them.
Regardless of what bolt type you use. The most critical ( little joke there) is that the bolts be properly tightened. The erector should first snug-up all the bolts to bring the steel (connection angle and beam web) into contact before fully tensioning the bolts. If the bolts are not first "snugged-up", you will have relaxation of the bolts in which they appear to be fully tightened but in reality are loose.
