Do you use these terms on your drawings???. As far as Im concerned its VERY bad practice, but I dont have the experience of working at many companies.
I have worked for a smallish toolmaking company for a few years in design & the 'old-skool' draughy's use some really sloppy techniques (in my opinion) and so far I have not completely followed thier practices in fear of it being frowned upon if I ever went anywhere else!!!
. (As in " whose this cowboy?!"
I am talking about a leader line to a counterbored hole and tapped hole on adjacent parts and just typing "M6 Caps" as an abbreviation for M6 Caphead Screws to give all the infornation in two words!!- which is still wrong in my view - as I like to put the dia of the counterbore,depths etc and say "Drill 5.0 & Tap M6 Through" or similar. A lot of "to suit" stuff like this goes on. I think its pure lazyness and so that no problems can come back to them.
Another thing is when assembling bushes and pillars/guideways/ bearings etc, they put "P/FIT" for press fit, "Push-Fit" and "Sl-Fit" for Slide Fit and just put a nominal dimension on the diameter in question on both parts Eg "20 dia P/FIT" rather than putting the limits on the two assembling parts to achieve the required effect. "good finish" "flat" "smooth" and "Close-Fit" etc are other classics!!!!.
Is it me? or does everybody else do this? what do you reckon to it?. *I am not learning the sort of limits needed for things going on like this* - I wouldnt know what limits to put on things to achieve a so called 'Slide-Fit' and I want to know these things.
They rely on the shop floor guys to make it to this and if its ever wrong its difficult to blame anyone, the designer says "well it says thats "Flat" and that part there is a "slide-Fit" there on the dawing", but surely the shop floor guy is quite within his rights to ask how good a "slide fit" is required and to what degree the flatness has to lie within etc?????. It all seems a nonsense to me - they just always make everything as accurate as possible to cover thier backs on the shop floor, and surely this is counter productive??.
Should I forget my principles and follow the flow, and never gain the knowledge, or should I keep quietly batting away for proper limits and forms (although I dont fully understand the correct/feasable proportions to apply). I understand that it would take a fraction more time to apply a proper value, but surely its better when there is a specific value to work to.
If other industries/companies do this sort of thing, then I guess Ill have to change my viewpoint a bit.
I know its a bit nit picking, but its always quietly bugged me since I started in design (got shown the other way (my way)at college).
Cheers,
Sirius.
Cheers,
Sirius.
