RWW0002
- Jun 10, 2011
- 389
I am in the process of re-writing some spreadsheets for changes to ACI318-08. While re-looking at slender walls, I have been using the PCA notes on ACI318 for worked examples to check by. When calculating Icr (ACI 318 Eq 14-7), PCA calculates "c" using the traditional nominal strength relationship between the neutral axis and the compression block (a/beta1). I have been using c corresponding to cracked transformed section properties. I feel like c corresponding to cracking makes more sense, but since the Ch 14 method is somewhat empirical I thought I would see what others thoughts were.
