I have a 4" concrete slab in my shop in excellent condition. Every summer there is a tremendous amount of pooling water condensation that results in a mess and hazard. It is also causing the epoxy paint coating to come off. There was no vapor or insulating barrier installed when it was poured.
I intend to solve the problem by covering the slab with an approved vapor sheet, and then an approved insulating board (blue DOW Styro or similar) and then pouring another layer of concrete over this.
My question: what should be the minimumm thickness for the pour over this existing slab?? (Shop only has automobiles as the heaviest equipment.) Is 2" OK?? I was thinking of the fiber reinforced material to avoid metal screen for this top layer.
Any opinions/ advice greatly appreciated!
Jon
Jon
