XR250
- Jan 30, 2013
- 5,972
Working a "new" Frank Lloyd Wright house. The Arch. is a devout follower so he is trying to exactly duplicate many of his details. On this house, I have a 14 ft. tall exterior window wall. The Arch. wants to frame it with a single 1 3/4x9 1/4 LVL vertical mullion spaced 48" o.c. between the windows. The axial load is 1,400 lbs and the bending moment is 1,700 ft-lbs (service). There is a horizontal 2x6 mullion at 8'-6" AFF. If I consider the LVL braced at 8'-6", the numbers actually work out. The wall contains eight studs so the cumulative bracing force is 2% x 1,400 x 8 = 224 lbs (I am assuming using 2% is reasonable for this situation?). The studs are flanked by a masonry wall at each end so resolving the brace force should not be too much of an issue.
So here is my question:
The 2x6 mullion is going to be flush with the inside face of the wall so it technically won't be bracing one flange of the LVL. I can likely talk him into a 2x8 instead of a 2x6. Also, there will be full 1x trim on all faces of the LVL which I am not taking into account. How do y'all feel about this situation?
There is really no budget on this job so I am pretty free to come up with other more expensive solutions. I am open to suggestions.
Thanks!
Thanks!
