V
vuuch
Guest
How do you turn off the auto dimensioning in the skecher? I want to create my own dimension scheme but cannot figure out how to turn this off... please help!
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
vuuch said:I cannot seem to add a dimension and/or delete ones that were created for me... Am I missing something?
vuuch said:WF 4.0 M090. Whle in a sketch if I push the dimension icon everything gets dimensioned. If I try to add another dimension or delete one nothing happens...
vuuch said:How do you turn off the auto dimensioning in the skecher?
That just controls the display, the weak dimensions are still there. Very dangerous config option in my opinion. Only way to get rid of them is turn off constraint manager. I think the original poster needs to figure out how to create dimensions!jvidal said:vuuch said:How do you turn off the auto dimensioning in the skecher?
While in Sketcher Mode go to Sketch > Options and deselect option Weak Dimensions.
To permanently disable the auto dimensioning add the following option to your config.pro file:
sketcher_disp_weak_dimensions no
dr_gallup said:That just controls the display, the weak dimensions are still there.
