TheNorseman
NX 9.0
Is there a way to reference plane surfaces of existing geometry in sketcher (without creating datum planes through the existing geometry)? From what I know now, I'm only able to reference edges and vertices of existing geometry. For example, if I have a 1x1x1 cube and my goal is to put a hole through it at .250 from the bottom surface and .250 from the side surface. In sketcher, I can only place dimensions referencing the edges of that cube, not the actual surfaces. I don't see this as being very stable because that edge can be eliminated with a chamfer, blend , or some other feature later in the model. I've also noticed that in drafting mode, you CAN select surfaces to dimension from which leads me to believe that somehow, this referencing option may exist in sketcher...thoughts/suggestions?
I'm relatively new to NX, coming from 15+ years of Pro/E. In Pro/E, I could simply add any surface of existing geometry that I want as a reference...I'm just looking for the NX equivalent to that. Thanks in advance for your feedback!
~Brian
~Brian
