Sketcher: Cant create specified dimension
  • Thread starter Thread starter ERamsey
  • Start date Start date
E
ERamsey
Guest
Morning,
Was wondering if anyone is getting this error in Sketcher when dimensioning from the reference line to a sketched line?
We recently went to wildfire 4.0 (M050) and a couple of us started getting the Cannot create specified dimension when we go to dimension a sketch. We'll click on the reference line then click the line that is sketched, then click to drop in the dimension and poof a no go?
I even ran a simple square sketch withdefault reference lines. Click the ref line , line on the square clicked in between for a linear dim and Cannot create specified dimension. Although if I clicked the ref line then the edge blue dot and then between for a lin dim it would go. I would erase try the other way nothing, or sometimes Iwould get itthat way (which I could have swore I've always gotten it that way)????
Seems to me like a bug or is it something else?
Any insight is appreciated.
In sketcher mode show "dimension" button is ON?
Seems to me quite imposible what you say
Cristelino
Actually I found what the problem was:
Minimum_angle_dimension was set to 0
Apparently someone needed a .50 degree angle and thedefault setting was 1. When changed to 0 and you have a hard time creating linear dimensions (as discribed in above post).
Once it was changed to something other than 0 (i.e. .1) creating linear dimensions become a lot easier.
Sounds insane but it works now. thanks
Edited by: ERamsey
