I have a 2D sketch plane containing bunch of closed contours each has to be boss extruded separately because of different depths. If I select a closed contour at the beginning and boss-extrude it, i will lose the rest of the 2D drawing. And if I extrude a plane on which the contours are located to make it 'physical' again I lose the whole drawing. I tried the "extruded surface" feature to have an imaginary plane/surface but didn't get anywhere either.
Hope I was clear, Any idea out there??
I am uploading the 2D drawing for your reference,
Thanks a lot for the reply,
