I have a closed sketch, made of 8 segments-4 lines, and 4 radius'(radius' are tangent to lines)-aka "a rectangle with filleted corners". I want to use the closed sketch as the centerline of a pattern of holes, where the centers of holes are equally spaced from each other. I'm not having any luck with sketch driven pattern. It seems to only select 1 of the path segments for the path.
