I've decided the best workflow routine for our company if we go with Solidworks will be using assemblies with all part sizes and configs controlled at the assembly level.
The prefered method for this is to use a skeleton sketch of planes, axes, points, etc and then creating all the parts "in context" constrained to the skeletons reference geometry. The skeleton sketch can then be completly controlled via a single design table.
That all makes perfect sense to me. But while researching I keep coming along suggestions to make the skeleton a part, and insert the part as an envelope instead of creating the sketch in the assembly. Various places mention this as the 'better' method, none explain why.
I dont see why this is a better alternative. Several times its been mentioned that this way its not included in bom's or mass property calculations. But reference geometry in a sketch in an assembly wouldnt be either, so i dont see an advantage.
I do see it as a disadvantage in the editing area. If its an assembly sketch, I can open the design table in the assembly, input all the changing variables, and see the assembly update.
If the skeleton is an inserted part, i need to open the part, open its design table, update the part, then update the assembly. That just seems more ackward to me.
I must be missing something. Can someone explain any advantages/disadvantages to either way? I'd hate to get my company going one direction with new software then have to change it 6 months down the line because my workflow wasnt optimum.
Thanks in advance !
Randy
Thanks in advance !
Randy
