prichmon
- Oct 5, 2010
- 32
I am working on installing a simple hood with stack to draft the heat from a 1,000,000 BTU/HR furnace with a vertical escape and horizontal run. The unit uses a blower running ~7" WC. Furnace opening is ~3"x 36". My current plan is to use a simple rectangular sloped up hood attached to stove pipe with multi layer construction to keep the heat and velocity as high as possible.
I looked in the 12th edition MERM and could not find anything on this subject. I did find design height; Stack effect head; and a simple draft equation. Based on research on chimneys has lead me to believe a 12" diameter pipe ~16' horizontal run with ~20' rise to get the draft I require. My gut tells me 12" will easily work but I feel I could lower my cost by using a more common size such as 8". However I can't find any data to support my gut.
The goal is to provide as much draft as possible with as little cost. I wish to avoid using forced air to increase draft so I'm limited to the chimney draft effect or some other means.
Can anyone point me in the right direction for a reasonable assessment of flow and sizing?
Rich
Rich
