Sizing a Parcel to specific Area/Square Feet
jiminem2
11
Say I have a parcel, 4 sides already exist its, its about 5 acres. I want to cut out a piece that is exactly 4,000 square feet. And I know what two sides I want to use to cut it out. I read the help file about slide bearings ect., tried it and can't figure it out. Anyone know the best/easiest method for doing this? Its illustrated in the help file but I still dont get it! Autocad LDD 2004
jim
This is one where it seems like it would be easier just using geometry than fancy gadgetry, but maybe I'm misreading.
The polygon is 4 sides. You know two sides. You will have to end up with a rectangle and two triangles. Start with a rectangle that best fits the area you want to subdivide. Place that, then form the two triangles around it. find their combined areas. I would guess that with 2 or 3 iterations, you will have your parcel exactly the # of sf you need.
Engineering is the practice of the art of science - Steve
Or a dummy like myself would just create a polyline around the general area (matching the two known sides) and add a field that displays the area of the polyline. Then toying with the other sides until I got it right on!
