Test setup: I need to have a disk, diameter = 1ft, spinning at 955rpm. A normal load of 2866lbs via an aplicator whose diameter is 0.25ft would be applied to the disk surface at 0.25ft from disk center. Ultimately I know I have to calculate the inertia of the system, torque or stalling torque, and the power (hp), however, I do not know generate my formulas for the particular application. How do I size the motor correctly. Any input would be greatly appreciated. Should you need more info, please feel free to contact me. Thanks
