dtmbiz
Aerospace
- Sep 23, 2008
- 292
Is it possible to identify 2 coaxial features of size (cylinders) @MMC for both to, establish a single Datum axis ? (e.g. A-B)
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
mkcski,mkcski said:I have a challenge - find an example in Section 7 (or any other material) where a feature is positioned to itself (like runout allows
AndrewTT said:What I meant by " not technically correct" was that the drawing in question (IMO) did not comply with the ASME Y14.5-2009 standard
greenimi said:Number#1:
pmarc, Evan and John are the best around here. Read some other threads and convince yourself.
To successful disagree with pmarc or Evan (to name just a few) is EXTREMELY hard and painful. You “almost” have no chance to win.
greenimi said:Number#2:
If the concept is not shown in the standard that does not mean is not correct or legal.
greenimi said:Number#3:
Quote:” The ∅.3125 features cannot reference themselves in their FCFs.”
A classic common misunderstanding in the industry = is that both datum features A and B are referencing a location back to themselves. However, that is not the case. The datum reference frame is simply specifying that the “Datum Axis” a single axis, is to be established using both datum features A and B together at the same time.
AndrewTT said:I don't want to put words into anyone's mouth, but I read that to agree with what I stated. Hopefully pmarc can come back and clarify his position.
pmarc said:The fact that someone won 99 discussions does not automatically mean that she or he will win discussion #100. So I would be very careful with using this kind of argument in any discussion (as a matter of fact I remember at least two threads recently in which I was proven that I was not correct and I admitted that).
epmarc said:Some feel uncomfortable in saying each datum feature diameter is controlled to their compound axis, in that if we were to “chuck-up” on both, they would be obscured and not measurable. The way around that is to not “chuck-up” on both, but rather probe them with a CMM and analyze the collected data, or put both in Vee-blocks which leaves them exposed to measure, or center drill the part and put it between centers, then measure every diameter to see how far off they are from each other. If everything is measured from the same axis, whether that axis is the proper datum axis or not, then every diameter is related to each other to within the sum of their tolerances to that common axis. In other words, if the part measures within the tolerance, it is good. If not, another measurement tactic can be used.
Evan said:1. Listen to and consider everyone's opinion, no matter who they are.
2. Scrutinize and question everyone's opinion, no matter who they are.
