TheDutchman
Industrial
Hallo,
I'm trying to simulate the impact of a human standing on the side of my staircase. You can see an image in the attachment. This is my first simulation so please have some patience
The problem is, when I try to Run the study for results I get the error about my model not being stable. Something about my restrains. As you can see, I fixed the 2 faces where my staircase is connected (fixed) so I cannot think of any other missed restrain. The rest of the assembly is mated togheter. As you can see, it is fully defined because I fixed 1 component. Hower changing this doesn't give me a different outcome.
I'm doubting that mating is not enough ? In real life my stair is a bend sheet metal with 2 plates welded on the side. The V shape below the stair is also welded to the sheet metal. But is mating not enough ? I tried weldments but only received more errors.
Can somebody give me an Eng-tip in the right direction
Thanks in advance
Thanks in advance
