Hi!
I want to simulate the structure of a flexible kite. It's made out of a solid tube connected to a membrane.
I'm struggling with obtaining a successful simulation with realistic kite thickness (0.08 mm).
When using thicknesses of that are much larger, I get a solution.
The error I'm getting is in attachment.
The membrane is modelled as shell homogeneous elements connected via a Tie constraint to the tube. I'm doing steady simulations.
Anyone has an idea what could be the issue or what could solve this?
Thanks!
Thanks!
