metalman8357
Materials
Hi all,
I'm working on simulating tests that we run out in the lab with FEA and I'd like to be able to compare the data in a meaningful way. For example, we generally apply a tensile or compression load to an assembly and we are able to monitor Load vs. Crosshead displacement. As a result, an assembly will continue to take an increasing load until a peak load is reached and the load will continue to drop off below the peak as the assembly deforms and can no longer carry the peak load. My question is, is there a way to model a load cell or reference part that I can put into my assembly where I can specify a prescribed displacement (0.100 in/min) and then monitor the load like a load cell. I'm assuming there's a simple trick that I can use but I've yet to really figure anything out yet.
Any suggestions would be helpful.
Thanks,
M
Thanks,
M
