Simple yield line question
canwesteng
1,724
I'm having a brain fart here, and no one in my office is terrific with yield lines. Normally I take the yield line mechanism of a flat plate (fixed support in this case) to be the red line, with the diagonals at 45 degrees. However, the project length about the horizontal of the diagonal yield lines decreases the steeper they get and the vertical projection doesn't change. So the steeper these get the weaker the mechanism, though this seems irrational. It is simple to just call the diagonals 45 degrees in the case of reinforcement equal in each direction, but in this case the short side has less reinforcement than the strong side, so it must be somewhat steeper than 45. Is there something I'm missing?
Okay, I see.
I believe that the ratio of the reinforcement amounts in each direction would result in some ideal selection of the yield line pattern, with a steeper angle than the 45 deg., as you suggest. But as the length of the diagonal line projections continues to reduce, the angle of yielding along those diagonals increases, thus increasing the work required and strengthening the mechanism. At some point these should balance out.
... I'll see if I can find time to work an example. I'm a bit puzzled now myself.
I ended up working it out - you do end up with more yield line in total as the diagonals extend, but the work ends up being UDL x area x delta/3, and in the area that is a rectangular instead of a triangular, the work is UDL x area x delta/2. So more yield lines with the triangle but less work expended as they drift, which ends up getting to an equilibrium point.
In my case specifically, more to the green and also up (negative moment resistance stronger at the bottom).
Ok. green makes sense then. I had thought you had more bars in the long directions…
Can't assume 45 deg or any other angle. YLA is an upper bound solution, so you'll need to find the angle that results in the lowest strength.
Well in an isotropic material, the yield lines will be symmetric, and if the supports are symmteric, you'll just end up with 45 degree angles.
The only place I use yield line theory is for steel plates. For concrete slabs, I prefer the Hillerborg strip method.
For a steel plate, the capacity of the plate is equal in all directions, so m = Z*Fy where m is the yield strength of the plate per unit length in any direction, Z is the unit plastic modulus and Fy is the yield strength of the material. The coordinates of the yield line can be found by differentiating the expression for internal work, then selecting the coordinates which produce the most critical value.
Waht is your go-to reference for learning/worked examples for this? No one in my office uses yield line theory, but it's something I'd like to learn.
I recommend Practical Yield Line Design by Kennedy and Goodchild, you can probably find it online for free. I've never heard of BA's method of differentiating the equations for work or energy - I just plug the formulas into mathcad and iterate the inputs til I'm happy.
Did you have to make a mathcad program or do they have something integrated?
It's really not a program, I just type in the equations (different depending on the yield line mechanism you are looking at), and just play with the inputs until I minimize the energy dissipated. This one is for a yield line mechanism described above on simple supports.
As @BAretired mentions, for steel it's easier as your yield moment is always the same along all lines. For most typical connections the controlling yield lines are also pretty well established. Design guide 16, some new equations in the manual for out-of-plane loads on HSS walls are all based on this idea.
A previous thread with a good AISC article that provides a good crash course to the theory: https://www.eng-tips.com/threads/yield-line-analysis-by-aiscs-carlo-lini-gt-using-sketchup.449422/
I also don't use it very often for slabs - probably should spend some time to setup my tools for that though.
I don't actually ever use it for slab design - just too tedious. Only ever for slab evaluation - once you know exactly the layout and the reinforcement, and only vary the loads, it's not as bad
YLA is general has been most useful for me for existing evaluation or construction mishaps in which you can have a chance to save the day.
