FullMetalBracket
- Jun 3, 2009
- 14
This is most likely a ridiculously simple question and I'm somewhat embarassed to ask it, but it's my first time performing such a calculation so cut me some slack...
I've been asked to select a linear actuator that will act on a 'beam' which is pinned on one end. The actuator pushes about halfway between the CG of the beam and the pinned support (not really relevant to my question). If I make a conservative guess for coefficients of friction, determining the required actuator force to begin motion requires solving a simple FBD. However, the actuator will obviously need to push harder than this value to actually accelerate the beam.
Actual speed here is not really critical, so what value to I attribute to this angular acceleration to determine maximum required actuator force? Am I going about this calculation completely the wrong way?
Any guidance is appreciated. Thanks!
