Hi All,
For a simple been both end fixed,under uniform distributed load, as per Roark's table 8.1 case 2d. Max moment is at edge of Wl^2/12, and hence max stress at edge. If we apply a load which will result a stress at edge exceed the allowable stress, or even exceed material yield stress, the beam will starts to plastic bending.
The question is as long as the load is applied, and the beam will start to bend, no longer straight,The beam geometry changed. will the formula M max = wl^2 / 12 remain true? Or the max moment will be shifted to elsewhere along the beam.
My point is how to find out the true load that will break the beam, or cause into plastic bending.
Thanks in advance for any comment.
Spoonful
Spoonful
