haynewp
- Dec 13, 2000
- 2,329
I was recently thinking about what bolt stresses are induced during the rotation of the end of a steel beam under an assumed pinned condition.
For example, you have an steel angle that is attached to the face of a thick concrete wall. The angle is being used to connect a W12 to the wall to support a floor. I usually think about vertical shear to design the bolts connecting the beam to the angle in this case, but what about the force that is induced in the bolts as the beam end rotates and slightly deforms the bolt holes to achieve a theoretical pinned end? Has anyone else looked at this before? Textbook references?
