I have an 8" check valve that I need to replace that is in the vertical plane 11" from the discharge of a 1435 gpm pump. We have replaced one in the past with another swing type check valve and it now makes the awfullest beating and banging noise when the pump is running. Since the swing check valve relies on gravity (weight of disk) to shut off, I believe that sudden surges in flow is causing the disk to relax and slam back against the inside of the valve since 1435 gpm of water discharged from a pump is pretty turbulent. I don't believe we have a water hammer problem, but I could be wrong. What I'm looking at replacing the current valve with is an APCO Series 600 Globe Style Silent Check Valve. To fit in place of our existing valve we would have to add a 9 3/8" spool piece giving a possible distance of 20 3/8" from the pump discharge to the check valve.
Now my questions: Does anyone think that the silent check valve is not a good idea in my situation? Can someone give me any pros and cons by going with a silent check valve? I have my own, but I'd like to see what others have to say. Any other advice is also welcomed.
P.S.> I have to be able to get this valve no later than 3.5 weeks from now.
