AlbertFM
- Oct 26, 2008
- 28
Hello all,
I have a problem with an electrical motor.
Two sidebands are apperaing next to syncronous peak and its harmonics (700Hz) while I am rumping up my electrical motor (1500 Hz nominal speed). A strange noise can be heard when sidebands appears.
I've been looking for some information of the problem:
Motor; with loose or otherwise defective rotor bars
Primary frequency is 1 x rpm. (With one or more sidebands on each side.) The difference frequency between a sideband and the primary frequency is equal to the rotor slip times the number of poles. Normally, its amplitude and amplitudes of sidebands are proportional to load.
The symptom for this defect at times produces excessive vibration at relatively high frequency. Instead of a sharp peak at rpm x number of rotor bars, there are many sideband peaks, producing what is usually referred to as a "haystack." The difference frequency between sidebands is usually equal to the electrical hum frequency.
I would appreciate if someone of you could suggest me other possible reasons of sidebands vibrations as well as an small explanation of what means the description I founded in internet.
You can find attached a spectrum. Speed is 700 Hz.
