Jan 26, 2003 #1 S satish Guest How to give the dimension in the drawing view which is added with shrinkage. the shrinkage value had given different in different direction.
Feb 1, 2003 Thread starter #2 R rbanga Guest It is possible by using driven dimensions. Create the dimensions in the drawing using Insert>>Dimension. It will display the dimension after adding shrinkage.
