JoelTXCive
- Jul 24, 2016
- 935
We have some crazy retaining walls that also serve as large architectural elements for a new residential development. The end result is going to be a hike & bike trail along a ditch with a "tiered look".
We looked at doing separate walls of different sizes, but due to the geometry and global stability issues, it was easier to do one huge shared footing between all the walls. (see below)
Our wall panels are vary in size, but the large ones are about 25ft in height and 50ft in length.
The architect would like to eliminate all control joints in the structure.
We are looking at using a shrinkage compensating concrete on the wall stems, but we do not have any experience with it.
We have a call into the manufacturer, but haven't heard back yet.
Questions:
1) Does the stuff work? (We are looking at Euclid's "Conex Type G" additive)
2) Any idea on the percentage cost difference between regular concrete and the shrinkage compensating mix? (We think the wall stems will be about 1000 cubic yards of concrete.)
Thank you!
Questions:
Thank you!
