showing individual components in table
TheGrunt
9
First let me apologize since this has probably been brought up before, however, I can't find it. I have an assembly drawing with some sub-assemblies in it and I want to create a table that shows each individual part name (not the names of the sub-assemblies). Is there a way to do this?
It is done with the tables repeat region settings. Look at settings for filters and duplicates.
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
To add a bit to Ben's answer- Make sure the repeat region is set to be Recursive under the attributes, so that it can see the parts in your subassemblies.
"By all means, do not use a hammer." (1925 IBM Maintenance Manual)
