Hello Engineering community,
I'm in the process of doing some major modifications to my X-Carve CNC router. I've already converted it to ACME screw drive, and am about to upgrade once again to linear rails.
My question is this: When designing for my timing belt that drives the screws, is it necessary to design-in adjustability for the center-to-center distance if it's very short? The dimensions in question are a 15mm wide GT3 timing belt, 70 tooth, running on 20t pulleys which come out to a 75.0mm center distance. My previous design has been running these belts for several months now, and have never required adjustment. I measured the actual assembled distance with the belts nicely tightened, and it measured exactly 75mm at all 3 locations (2 Y-axis motors and 1 X-axis motor).
In the realm of machine design, with this short of a timing belt, is it common practice to design in adjustability? Or fixed distance? Since I need to make a new set of machine plates, I'd like to know if I should design a fixed distance or keep the slots (currently +/- 3mm from 75mm centers).
Thanks for any input!
